PXI
Synchronizing two same DSA devices (PXI 4495) in PXI 1052 Chassis at similar rates
I am trying to synchronize two PXI-4495 devices using Reference clock synchronization method. I have followed the steps mentioned in the NI support platform using PXI chassis backplane (PXI_CLK10) for synchronization.
But, the Error -89136 is displayed. It shows that "The specified route cannot be specified because hardware does not support it".
Is the issue with the code or hardware? Kindly suggest a solution.
Swetha
(898 Views)
Show us your code or we can't tell if the issue is on your code.
https://tmesystems.net/
(865 Views)
Simplest way is to use DAQmx Channel expansion to let the driver take care of sync.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8XiSAK&l=en-IN
Santhosh
Soliton Technologies
(862 Views)
