PXI
System bandwidth and slot bandwidth
I am trying to find a suitable chassis for a PXIe-5186 card. Which chassis is recommended?
I noticed that there are system bandwidth and slot bandwidth for chassis, how can I check how much bandwidth is required by the card?
For some chassis, it will include OCXO for increased clock accuracy. May I ask how the clock signal is connected to the PXIe card? Through chassis internal connection or need to through a cable? Can I have more information about this OCXO option for chassis? Can I connect an external 10 MHz reference clock to the system?
Thank you.
Message 1 of 1
(1,923 Views)
