PXI
TB2627
-Planning to use PXIe 2527 and instrumenst connector is TB2627
-HV6-BAN4 Cable Assembly (0.2m)  -Please infrom that this cable assembly is complete with adapter on both side or only cable
- I couldb't find the cable image
- 100-Pin HDI Right Angle Mating Connector  - on PCB board side is this correct connector
Please privide suggestion.
-Thanks,
 Sudhan S
(3,648 Views)
Hi Sudhan,
You can refer to this link for the information you want on HV6-BAN4.
http://digital.ni.com/public.nsf/allkb/125556EA1B1744A4862578DA006E7D22
This cable is for ease in final connections.
And 100-pin HDI right angle mating connector is for termination on the other side.
Hope this helps!
(3,537 Views)
