PXI
Test of a ram component with PXI solution
I'd like to know a test functional solution with a PXI system (software and hardware) for a example of board with a single ram 1024x8 (with a pin of chip selected and a pin of w/r)
(3,572 Views)
Are you looking for a PXI board that will allow you to interface with a RAM chip?
If so you may be interested in the following KB:
http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/f79df6929dea7e27862567900058d1fe?OpenDocument
It tels you what you must be familiar with to develope a PXI device and lists a couple of vendors which sell boards that allready interface with the PXI bus so you can develope the rest or your hardware.
If this is not what you were looking for, please rephrase the question.
Amaury Rolin
Applications Engineering
(3,572 Views)
