PXI
Test panel driver incompatible
im doing a calibration on my PXI and im getting this error any suggestions photo attached
I circled what i think it its but dont know what the fix would be?
thanks in advance
-Kurt
(4,972 Views)
Indeed you might need to update the version of the driver of your PXI system. First you will need to check if this version is compatible with the version of LabVIEW installed in the remote system (you can check that from the link below). Then you can download the driver from here.
http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248
MCOTO
(4,958 Views)
