PXI
The device could not be calibrated -201295
In one PXIe slot I have the DAQ card PXIe-6363 connected. When I press the button "Self-Calibrate" in MAX I get the next error message:
Status Code: -201295
Device could not complete the calibration operation
I have done that with load connected to the card and also with no cable connected to the card. Does anyone know how to solve that problem?
Much thanks for your time and dedication!
(4,048 Views)
in the self test calibration the board measures a signal and compares it with an internal reference. The issue might be related to a malfunction in the measurement or in the internal reference. In any case, is very likely that the board needs to be repaired.
My suggestion is to test it with the DAQ Diagnostic Utility and contact NI support attaching the report of the Utility.
(3,958 Views)
