I am experiencing the same problem. Our program periodically monitors data and eventually save it for post-processing. While it's searching for suitable data, it creates one file for every channel (32 in total) and starts streaming data to these files. If it finds data is not suitable, it deletes the files and creates new ones.
On our lab, we tested the program on windows and then on RT and we did not find any problems.
Unfortunately when it was time to install the PXI on field (an electromechanic shovel on a copper mine) and test it, we've come to find that saving was taking to long and the program screwed up. Specifically when creating files (I.E. "New File" function). It could take 5 or more seconds to create a single file.
As you can see, field startup failed and we will have to modify our programs to workaround this problem and return next week to try again, with the additional time and cost involved. Not to talk about the bad image we are giving to our costumer.
I really like labview, but I am particularly upset beacuse of this problem. LV RT is supposed to run as if it was LV win32, with the obvious and expected differences, but a developer can not expect things like this to happen. I remember a few months ago I had another problem: on RT Time/Date function gives a wrong value as your program runs, when using timed loops. Can you expect something like that when evaluating your development platform? Fortunately, we found the problem before giving the system to our costumer and there was a relatively easy workaround. Unfortunately, now we had to hit the wall to find the problem.
On this particular problem I also found that it gets worse when there are more files on the directory. Create a new dir every N hours? I really think that's not a solution. I would not expect this answer from NI.
I would really appreciate someone from NI to give us a technical explanation about why this problem happens and not just "trial and error" "solutions".
By the way, we are using a PXI RT controller with the solid-state drive option.
Thank you.
Daniel R.
Message Edited by Daniel_Chile on 06-29-2006 03:05 PM
