PXI
The output problem of waveform generator
PXI waveform generator sends out voltage signal, I want to know how to take and send out current signal.
(1,126 Views)
The common generators output a voltage signal. If not explicit stated you can't switch that output to a controlled current output unless your load impedance is known. And usually the output current of these generators is limited.
Solution: Add a voltage controlled current source.
Minimum Needed informations:
Bandwidth
Current range
Max voltage range
(Kind of expected loads)
Greetings from Germany
Henrik
LV since v3.1
(1,089 Views)
