PXI
Thermocouple as analog input?
I would like to re-purpose an older M series NI PXI-6229 for reading J thermocouples.  Before I spend time trying this out I thought I would ask the questions.  Has anyone done this?  Does it produce good results?  The analog inputs support a +/- 0.2V range with 16 bit A2D.    The manual of the NI 6229 indicates adding a resistor to AGND when using the inputs in DIFF mode.  Directly connecting AI- to AI GND or using a 100x resistor for J thermocouple?
If I use a PXI mux, recommendations on settling time for thermocouples, before applying the A2D settling time?
Cheers,
J -
(2,251 Views)
Hi J,
I certainly never have tried this myself. It's possible, but you'll be losing out on some features of thermocouple hardware like CJC compensation.
For your reference, I included a white paper regarding handling noise which may be helpful for this application.
Field Wiring and Noise Considerations for Analog Signals
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
Best,
Ben
Technical Support Engineer
(2,224 Views)
