PXI
Time data is not shown properly in DAQ
Hello friends,
I would like to measure analog voltage with NI PXI-1050, I have connected my signal input line to SCXI 1125 module via 1320 Terminal block,I have used channel a1 of terminal block out of 08 available channels. The remote PXI controller is running on RT. I have made the connectionof signal output of DAQ assistant to signal input of write LVM VI. I am getting the LVM file but in those files the X0 value is showing like  2.718XXXXXE9  which is not varying in the measured signals ,it is showing the same constant value for X0.
What I should do so that this problem get solved so that the initial value of x0 i get 0.00000E and in further readings it is incrimented by time interval(i,e Delta T).
I am also attaching the VI along with this. When I run the VI, I dont get the time values correctly in the test.lvm file.
Please help me in this.
Herok
Thanks...
Message 1 of 1
(3,151 Views)
