PXI
Time synchronization card not recognized under MAX
I'm currently working on a data acquisition system based upon a real-time target (PXIe-8133 embedded controller), a PXIe-6366 acquisition card and a PXI-6682H for synchronization to GPS time.
Both NI-Sync 3.2.2 and NI-TimeSync 1.1.0 are installed respectively on the host PC and real-time target. But the PXI-6682H card is not recognized under MAX.
Does anyone have an idea on how to deal with this problem?
Sincerely yours,
(3,970 Views)
Did you install VISA? Which version of LabVIEW do you use and which OS do you have on your computer?
Here a link that could be useful for you : PXI-6682 Identifies with VISA on Windows 7 64-bit System
It seems the issue has been solved with NI-Sync 3.3.
You can also try to install DAQmx :
DAQmx Download
Don't forget to check the compatibility between your drivers and your LabVIEW version :
Compatibility between LabVIEW and NI-Drivers
Jérémy C.
NI France
(3,952 Views)
