PXI
Trace in MAX of a NI-DAQmx Global Virtual Channel
I would like to visualize a trace in "Historical data" bound to a NI-DAQmx Global Virtual Channel. Is it possble? How?
Besides the NI-DAQmx Global Virtual Channel, I also created a shared variable in my project bound to the NI-DAQmx Global Virtual Channel. In my case the path is \\FAST_SCADA_PC\Analog Inputs\PIT5-SCC.
Thank you,
Piero
(3,148 Views)
Dear Sir,
Thank you for your post on our internet forum.
Please use the Labview dataloging and supervisory control module to add this functionality to your shared variables ;( https://www.ni.com/en/support/documentation/supplemental/06/using-the-labview-shared-variable.html )
You will use the citadel database, please find the following knowledgebase for this; https://www.ni.com/en/support/documentation/supplemental/12/logging-data-with-national-instruments-c...
The following knowledge base explains about using DAQmx and OPC; https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2CMCAY&l=en-US
If you have any questions, please don't hesitate to contact me,
Martijn S
NINL
Martijn S
NI Netherlands
(3,098 Views)
