PXI
Trigger in PXI
I am a student and work with PXI-5114 board. I acquire data and watch it on the Graph. But I have a problem with trigger. When I shift trigger level it works relative to the center of the graph. I want my trigger work from the beginning of the graph. Does anybody know how to do that?
Regards
(4,625 Views)
Can you explain more in details, what type of trigger do you use? Can you post the VI or post a screenshot of your applicaiton?
Kind regards,
Ion R.
(4,614 Views)
I am looking for input of trigger position in NI-SCOPE driver. When you take a look on SCOPE Soft Front Panel there is a slider below chart. That is trigger position. I am doing my own oscilloscope and I wonder where can I find input of trigger position.
Regards
(4,597 Views)
What exactly do you mean you are developing your own oscilloscope??
I still don't understand what exactly are you trying to achieve.
Can you post a printscreen of your application?
Kind regards,
Ion R.
(4,586 Views)
If you refer to the fact that are trying to program an oscilloscope application, there is a VI for triggering.
http://zone.ni.com/reference/en-XX/help/370592N-01/scopeviref/niscope_configure_trigger__poly/
Kind regards,
Ion R.
(4,585 Views)
