PXI
Triggering PXI Counter Timer from SMB connector on PXI Controller
I have a PXI-8196 Controller in a PXI-1045 chassis with 3 PXI-6602 Timer Counter cards among other PXI I/O cards. I would like to set up three counter timers to be triggered off of a signal connected to the SMB connector on the front of the controller. How would I do this in Labwindos CVI?
(3,084 Views)
Q?,
Unfortunately this connector can only be used by the watchdog functionality of LabVIEW RT if the controller is running RT. Instead, you can certainly route a single signal into one of your countersand route it to the others through the backplane. Would this be an option?
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,072 Views)
