PXI
Trying to install 4 pxie-4300 in one chassis
I am trying to install four PXIe-4300 cards in one PXI chassis (PXIe-1085).  No matter which slot I try to install the fourth card, the computer will not boot.  Is there a limit to how many PXIe-4300 cards you can install on one chassis?
(5,029 Views)
There's no limitation. How are you controlling your chassis? And what versions of software are you using (MAX, Platform, DAQmx, etc..)?
(4,988 Views)
PCIe-8381.  See attachment for software
(4,983 Views)
After searching with google, I discovered the MXI-Express Bios Compatibility software.  This took care of my issues and I am able to populate the PXI chassis in the configuration I want.
(4,958 Views)
