PXI
Trying to install DAQ. Correct device isn't available under Devices and interfaces > create new
I have everything plugged in as it should be (device in the pxi and hooked up to a BNC2110). I cannot find the correct driver listed under "create new" for Devices and Interfaces. I'm using a PXI-1031 with  a PXI-6221 DAQ card but I can't get it to detect and install correctly.
Things that are listed under "Create new":
NI-DAQmx SCXI Chassis
PXI-1010 (SCXI)
PXI-1011 (SCXI)
PXI-1050 (SCXI)
PXI-1052 (SCXI)
SCXI-1000
SCXI-1000DC
SCXI-1001
NI-DAQmx SCC Connector Block
SC-2345
SC-2350
SCC-68
NI-DAQmx TEDS Interface
BNC-2096
Any help on how to get the correct device to be available to be installed would be greatly appreciated.
(5,271 Views)
Hi JoshKlein,
Which version of DAQmx driver you have installed? Also, is MAX not detecting your DAQ Card or your PXI chassis?.
Best,
Carmen C.
(5,248 Views)
DAQmx version #9.2.0
I'm not sure how I would tell if the DAQ card was detecting correctly. I think that it is but you can look at the screenshot I've attached. Or if you tell me how to check I can pass that info along.
(5,244 Views)
JoshKlein,
According to the screenshot that you've attached, it seems like you've installed correctly the DAQ Card, you can create Task with it and use Test Panels. Also you can click on Self-Test in other to verify the correct functionality of this device.
Best,
Carmen C.
(5,230 Views)
