PXI
URGENT: PXI-1033 and DAQmx problem
I bought new laptop with Express Card slot Dell Inspiron 6400. I have PXI-1033 with integrated MXI bridge, Express Card 8360 and PXI-modules: PXI-6251, 6115, 5114 and 4071. I installed drivers 8.3 and plugged in PXI modules into PXI-1033. I first power up PXI-1033 and than power up laptop (with Express Card in it). Laptop can not start, again can not, blue window, and at last start. In MAX is listed PXI chassis with bridge and all modules, but mx is not listed and I can not use it from LabVIEW. What is the problem?
(3,424 Views)
To clarify, do the PXI modules show up under DAQmx devices?  What color is the Link LED on the 1033?  Do the cards all show up in Windows Device Manager correctly?  Also, are you able to power on the laptop successfully now every time, or does is have trouble booting each time you try and start it up?
Have you inspected the MXI cable for bent pins or any visible damage?
Thanks!
Adam W
Applications Engineering
(3,406 Views)
