PXI
USB6255
         I am planning to use usb6255 and two  scb68A together in my project, Can anyone please advise what kind of cable(cable part number) should be used to connect them ? Thanks!
Message 1 of 11
(3,817 Views)
Here is a list of supported accessories.
https://www.ni.com/en-us/support/documentation/supplemental/16/62xx-models---daq-multifunction-i-o-c...
Santhosh
Soliton Technologies
Message 2 of 11
(3,796 Views)
Thank you ! Santo
so I can use SH68-68-EPM cable for one scb 68A, and SH68-68-S cable for the second scb 68A, correct?
Message 3 of 11
(3,777 Views)
Yes, that is correct.
The same information is available in M-Series user manual pg#30
Santhosh
Message 4 of 11
(3,772 Views)
oh, it is SC68-68-EPM and SHC68-68 for scb-68A. not SH68-68-EPM and SH68-68-s, they are different.
Message 5 of 11
(3,769 Views)
Above are different cable information for USB6255, begin with SC and SH, SHC, which one is correct one ? or they are same? Thanks!
Message 6 of 11
(3,739 Views)
This document explains all about cables - https://www.ni.com/en-us/support/documentation/supplemental/17/main-page---daq-multifunction-i-o-cab...
Santhosh
Message 7 of 11
(3,724 Views)
Accepted by topic author wwn
Thank you very much for your help! Santo
Message 8 of 11
(3,710 Views)
Hi Santo,
              when I order USB6255, do I need order AC adaptor and usb cable which connect usb6255 to computer? or both are included in USB6255 order package? if require separate order, can you please advise the part number for both? Thanks!
Message 9 of 11
(3,633 Views)
@wwn wrote:
Hi Santo,
I am not sure about that, since it did not recommend a USB cable or power adapter while placing an order I would assume that those come with the USB-6255.
Santhosh
Message 10 of 11
(3,615 Views)
