PXI
USE 272x in veristand custom
Hi Guys,
 Now I am building project use 272x custom in veristand.I only change value from 0 to 65 om. How to change value geater 65om?
Thanks and Best regards
Hoang Dung
(717 Views)
Are you using NI-272x-Resistive-Simulation-Custom-Device?
Which model of resistive switch are you using?
https://tmesystems.net/
(694 Views)
Hi Zyong,
 I  am using model as below for 2727
(688 Views)
Using a simulated device, I don't have any issue setting up to 16320 ohm.
(680 Views)
Hi Zyong,
 for display on Veristand, It still true but when i measure actual, it is not correct. It only max 63.5 Ohm
(665 Views)
Try using the Test Panel in NI MAX to see if it is a hardware issue.
(643 Views)
