PXI
Unreliable access to PXI boards
I am using a PXI-1033 chassis with PXI-5405, PXI-6541, and PXI-5105 connected to a PC via PCI-PXI 8331 MXI.  The first time I loaded the drivers and software, then turned off the PC (Windows 7), then I switched on the PXI-1033 and all of the boards were identified and access LEDs turned on.  Several days later, when switching on the PXI-1033, the chassis powered on successfully and was linked, but the PXI boards' access LEDs never turned on.  I tried several times switching on and off in different orders with no success.  Each time, the devices showed up in device manager, so I tried re-installing the drivers.  That day the devices worked correctly again.  But now, 1 week later, the access LEDs do not turn on!
I need a solution that doesn't require reinstalling all drivers everytime I want to use the devices.
Thanks!
(3,425 Views)
Hello rpfrancis,
When the access lights on your modules are not turning on, do the cards themselves still function (can you get input/output from them)?  Do the devices still show up in MAX?  You are correct in turning on the PXI-1033 chassis first.  You will always need to boot the chassis first, then the PC.
Also, have you taken a look at the troubleshooting section of one of your module's user manual?  There is a section about access LEDs not turning on that gives steps to try to fix the issue.  It sounds like you may have already done a couple of the steps, but I recommend trying the each step in the manual.  Let me know!
Joe S.
(3,419 Views)
Thank you for the reply, Joe.  Yes, I have repeatedly gone through the troubleshooting steps.  After manually removing and reinserting the boards for a second time the access LEDs finally turned on this afternoon.
 It did this last time, and then stopped working about a week later.  I will monitor closely to see if there is anything that causes it to stop working this time.
Thanks again,
Robert
(3,409 Views)
