PXI
Upgrading 8102 Controller
Hi
We have an 8102 controller that we benchmarked at around ~ 40 MB/s transfer rates to the hard drive.  Limited by the 5,400 rpm disk that is in there.  For a stream to disk application, we were hoping to be up in the 50 - 70 MB/s range to be able to aquire all the data that we need.
I understand that the HDD that is in there now is connected by a SATA I connection, rated at 125 MB/s, but it is a custom flex that connects to the drive.  If we were to upgrade the hard drive to a SSD with transfer rates that will exceed the rated SATA I connection.  Will we be able to saturate the SATA I connection and approach the 125 MB/s limits?
(5,246 Views)
Hi ShaunS,
As long as your SSD can write to disk at that rate, you should be able to get pretty close to that 125 MB/s limit.
Kaitlin N.
(5,220 Views)
That is good news.  Thanks!
(5,209 Views)
