PXI
Using Laptop hard disk with PXI
I would like to use a 30 GB 2.5" laptop hard disk with a PXI controller. Has anyone tried using a different hard disk with the PXI (other than the one supplied with the controller)
(3,620 Views)
What type of controller you have? Is it a PXI-8156B, PXI-8170, PXI-8176, other?
In theory you could use any 2.5" hard-drive. See KnowledgeBase linked below:
KnowledgeBase 23DDKSV7: What Kind of Hard Drive Is in My PXI Controller?
However, I would first check the manual of the hard-drive to see what does it require.
If you have a PXI-8174, PXI-8175 or PXI-8176 controller you can see the specifications of the hard-drives that ship with these controllers at the following link:
Fujitsu Hard-drives used in PXI-8171 family of controllers
Hope this helps,
Claudia Lorente
N
ational Instruments
http://www.ni.com/ask
(3,620 Views)
I am currently using a laptop 3.5GB in a PXI 8156 controller without problems, you will lose the image and drivers obviously but I found all that I needed on the NI site.
(3,620 Views)
