PXI
Using NI PXI 4462 for analog current monitoring
Hi, my name is Gabriel.
My question is: am I able to use Ni PXI 4462 to monitoring an analog current input from 4 to 20 mA?
Thank you.
(2,509 Views)
Hello gabrielschubert,
Before advice you to use or not this PXI module, I need more information about your application to help you find out the best hardware for you.
So, can you describe with more details your application?
César Teixeira
Certified LabVIEW Developer - CLD
Applications Engineering
National Instruments Brazil
(2,466 Views)
