PXI
Using PXI Star line for Sample CLK with 6551.
Im trying to clock 5 6551s in a PXI-1006 chassis and a5404 in slot 2.   I have configured the 6551s to use the start line as the sample clock but I still get the error
Possible reason(s):
Driver Status:  (Hex 0xBFFA49B5) DAQmx Error -200586 occurred:
Hardware clocking error occurred.
If you are using an external sample clock, make sure it is connected and within specifications.  If you are generating your sample clock internally, please contact National Instruments Technical Support.
Device:  PXI2Slot17
Status Code: -200586
Any ideas why?
Brian
(3,070 Views)
Nevermind...problem solved.  I was exporting the wrong signal to the star line.Smiley Surprised
Brian
Message Edited by BrianPack on 11-28-2005 12:07 PM
(3,043 Views)
