PXI
Using USB-8473 on PXI-1042
I have a PXI-1042 with a PXI-8101 controller. I want to use my USB-8473 with it. So I have plugged the USB-8473 into the usb slot of the PXI-1042. I have restarted the chassis, and made sure that the NI-CAN2.7 was installed on the chassis. However, when I go to the "devices and interface" in MAX, the USB-8473 still haven't showed up. What is wrong?
The PXI-8101 is running LabView-RT.
Thanks!
(3,786 Views)
Hi Bladhart,
The USB-8473 is not supported under LabVIEW RT.
Here is a KB on the issue:
Can't See My USB-CAN Device Under My Real-Time Target
http://digital.ni.com/public.nsf/allkb/56D34FFC958E2D5D86257777006CF970
The readme for the driver also shows what devices are supported under RT
http://ftp.ni.com/support/softlib/embedded%20networks/CAN/driver/ni-can/2.7.2/readme.htm
Hope this helps!
Chris T.
(3,764 Views)
