PXI
Video Output for PXI Embedded Real-Time Controller ?
I plan to purchase a PXI Embedded Real-Time Controller for security monitoring.
Is it possible to use the video output of a PXI Controller running RTOS to display messages from a LabVIEW RT application ? According to the documentation, it seems that the use of the video output is only possible for PXI Controllers running Windows XP.
Does it exist a specific application to do this with LabVIEW RT ?
Thanx.
H.L.
(5,046 Views)
What kind of message do you want to display?
Here you can find a similar post on the forum:
using the local monitor from a pxi labview rt system as the HMI without a pc attached.
Regards
Yann C.
France
(5,024 Views)
Thanx for the answer and for the link.
My plan is to use a PXI Embedded Real-Time Controller for security moritoring.
Security regulations require special logo and text to be displayed according to the conditions in the zone under control. Thus I have to continuously display a static image among various statutory ones, each one corresponding to specific security conditions.
(5,007 Views)
It's not possible to display static image on a PXI running only RTOS.
You can use the  RT hypervisor to have an RTOS and a Win XP on the same PXI.
 Regards
Yann C.
France
(4,992 Views)
Hi Yann,
The situation seems a bit confusing as in the link you've given above using the local monitor from a pxi labview rt system as the HMI without a pc attached, two messages (here and here) say that it is possible to display an image on the video output of a PXI RT controller using a function of the NI-IMAQ librarey (namely, the IMAQ RT Video Out VI) !
I have the NI-IMAQ library but no PXI controller to test if this solution should work or not 😞
Does anyone have the answer ?
Thanx,
H.L.
(4,971 Views)
Mea Culpa, you're right! With PXI Controller it's possible to use the NI-IMAQ library and the IMAQ RT Video Out VI. I'll try this function and send you some return.
Regards
Yann C.
France
(4,956 Views)
Accepted by topic author Herlag
All right, it works using the IMAQ RT Video Out VI : pictures are correctly displayed via the video output of the PXI Controller running RTOS.
Thanx.
(4,832 Views)
