05-05-2019 04:39 PM
I have bought a NI PXIe 4081. Does it have any minimum time specs for reading a voltage or current value?
Thanks.
Solved! Go to Solution.
05-06-2019 09:26 AM
The NI PXIe 4081 will read AC voltage in less than 15 microseconds, and will acquire readings from all other functions of the DMM in less than 1 microsecond.
See page 16 of the PXIe-4081 Specifications Manual Linked Below.
http://www.ni.com/pdf/manuals/375254c.pdf
I hope this helps.
