PXI
WEBSERVER USING LABVIEW RT
Dear Sir
i am developing a application which has to run in the RT controller presently i am controling and monitoring the application using HOST PC. is it possible to do both control and monitor using web server concept from direct internet if it is possible please send me some examples and some links which will help in developing the application.
Thanking you and waiting for u r reply
sathyendra n
(3,560 Views)
The easiest way to accomplish this would be to use the Remote Front Panel feature of LabVIEW 6.1 which allows you to publish the VI to a webpage where users can connect and control the VI. Remote Front Panels can also be used on RT targets although the procedure to set it up is slightly different.
JR A.
Application Engineer
(3,559 Views)
