PXI
Waveform on SMU
HI.
I need generate sinusoidal signal on PXIe-4141 frequency up to 200 kHz. Is it possible? What max frequency I can generate? Thanks.
(2,171 Views)
You could generate upto 100ksps per board.
As to your requirement, 200kHz would not be possible with the update date. You would be able to do only 50kHz which would like a triangle wave. If you would like a better defined wave, at least 10 points per cycle, would yield only 10kHz.
Please refer to this document and VI to try on your hardware.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DcK9SAK&l=en-IN
Santhosh
Soliton Technologies
(2,062 Views)
