Home
Community
Discussion Forums
Most Active Hardware Boards
PXI
Topic
PXI
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
What is Win C ? Is this an RT prog. dev. tool? If so, can I program my appln using this and run in PXI-RT ?
G Sudheer
Member
12-22-2001
05:10 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
What is Win C? Is that a Real Time application developer? If so, can I use the same to develope my RT application and run in a PXI chasis with PXI-8145RT, E series, DIO, motion and timer/counter modules?
0
Kudos
Message
1
of 2
(4,931 Views)
Reply
Re: What is Win C ? Is this an RT prog. dev. tool? If so, can I program my appln using this and run in PXI-RT ?
Chad_H
Member
12-31-2001
10:29 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
G Sudheer,
LabVIEW Real-Time
is the only development environment for developing applications for RT Series PXI Controllers.
Chad H.
Applications Engineering
http://www.ni.com/ask
0
Kudos
Message
2
of 2
(4,931 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
