PXI
What is it "USB-USB Network Bridge Adaptor" in my NI PXI-8106 controller?
Could I disable this device in "Device Manager". Because it is generating new network card and same application which is using PC information is using this "interface" to generate PC information for licensing.
I am using TestStand 4.01 and LabVIEW 8.5 and Acculogic ScanNavigator
(4,551 Views)
Accepted by topic author JCC_(SK)
Hi JCC,
I don't think that's an NI software/driver, you can certainly try and disable it in Device Manager and see what effect it has. You can always enable it again if it causes problems when disabled.
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
(4,540 Views)
i see that your test configuration, includes Acculogic ScanNavigator, TestStand, and LabVIEW by chance are you automated the execution of your project nodes in your scannavigator workspace (.tnw) from teststand with a labview vi?
(3,627 Views)
Why are you resurrecting a 5 year old thread?
(3,621 Views)
Yes, we did.
TestStand custom steps written in LabVIEW call Acculogic .NET function
(3,591 Views)
Could you send me an example of that? I want to run my ScanNavigator projects (via workspace) from TestStand to reduce operator interaction operating ScanNavigator and TestStand.
(3,584 Views)
