PXI
What is the PXI-5401 Voltage Resolution?
From the data sheet for the PXI-5401 FGEN the voltage output accuracy is listed as +/- 1dB with a Output Attenuation of 0-73dB and Resultion of 0.001 dB steps.  How do I use this information to calculate the volatge accuracy/resolution I would have when applying a 2.4Vp-p sine wave from the 5401?  Thanks
(3,184 Views)
I found a great KnowledgeBase article that describes what you are after
http://digital.ni.com/public.nsf/allkb/93F9D5FD71F4618986256C6F0004DE03?OpenDocument
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(3,172 Views)
