PXI
When will a Thunderbolt PXI chassis be available?
10mbps interface to PCI!
Message 1 of 9
(7,196 Views)
Hello There,
I am unsure about what you are referring to.  The PXI Platform already provides up to 132 MB/s system bandwidth and is based on the PCI platform specifications.  Moreover, the PXI Express can deliver up to 1 GB/s per-slot dedicated bandwidth and up to 7 GB/s total system bandwidth.  Below is a link that explains more about the PXI and PXI Express specifications:
What is PXI?
http://zone.ni.com/devzone/cda/tut/p/id/4811
Roman Sandoval | National Instruments | RF Systems Engineer
Message 2 of 9
(7,176 Views)
The "Thunderbolt Port" is an Intel standard that uses a low cost cable to deliver PCIe to daisy-chained peripherals. It would be AWESOME if NI would support Thunderbolt - and particularly for PXI chassis. Thunderbolt is AWESOME - and it is a standard. There are already quite a few Thunderbolt peripherals for MacBook Pros - including a Thunderbolt - PCIe adaptor by Sonnet that will allow Mac laptops to connect to the current PXI chassis using the PCIe solution.
Message 3 of 9
(6,934 Views)
Correction, Thunderbolt IO delivered with new MacBook Pro computers is in fact 2 channels of 10GBps throughput each on a single connector.  Each TBolt channel is four times faster than PCIExpress which is rated at a (mere) 2.5 Gbps.   It would be good to know when PXI will support this interface because Apple pro laptops are and will for a long time henceforth be delivered with Thunderbolt IO...replacing PCIExpress (2.5 Gbps)  and completely leapfrogging USB3.0 (5 Gbps).
Message 4 of 9
(6,737 Views)
The use of the Thunderbolt IO platform and the potential of this technology being implemented with our future hardware is not public knowledge and cannot be disclosed currently.  Please allow National Instruments Marketing to prepare a statement that addresses the adoption of different future platforms including the Thunderbolt IO.
Message 5 of 9
(6,717 Views)
What about Thunderbolt 3 to PXIe MXI in a PXI Express Chassis?
Message 6 of 9
(5,492 Views)
Hi kmcdevitt,
To follow up, the PXIe-8301 will be available later this summer and provides Thunderbolt 3 control of PXI - for a bit more info, check out this white paper:
http://www.ni.com/white-paper/53757/en/
Michael Keane
Message 7 of 9
(4,718 Views)
Looks like the 8301 is released
http://www.ni.com/sic/configurator/configure.action?sfId=NI&wcs_l=en-us&wcs_k=pxi-remote-control-mod...
=AK2DM
Message 8 of 9
(4,513 Views)
Yes, the PXIe-8301 is orderable! Please note that we are working to resolve a web issue regarding the card’s displayed accessories. The applicable part numbers for order include:
  • PXIe-8301: 785679-01
  • Active Thunderbolt 3 Cable: 785607-02
  • Passive Thunderbolt 3 Cable: 785608-02
Michael Keane
Message 9 of 9
(4,507 Views)
