PXI
Where should I write if a found a potential error in the documentation of a NI product?
I found some errata in the documentation for the PXI 2521. What is the best way to submit my findings?
www.vartortech.com
(2,493 Views)
Well, I am going to write my findings here. Hopefully it will reach the right person within NI:
For the latest NI PXI-2521 specifications, found here: http://www.ni.com/pdf/manuals/373797a.pdf
Page 6
Figure 2. NI PXI-2521 Connector Pinout
NOTE: This errors are also in the manual online: http://www.ni.com/documentation/en/pxi-relay-module/latest/pxi-2521/pinout/
CH2+ is missing. Instead, COM2+ repeats twice.
COM24- is missing. Instead, CH24- repeats twice.
The following error is found only in the PDF file:
CH12+ is missing. Instead, it reads C12+
www.vartortech.com
(2,464 Views)
Hello Enrique
Thank you very much for the feedback. To make these reports we recommend creating a service request so it can be evaluated and reported by a Technical Support Engineer.
For this one, I already created a Corrective Action Request (#735581) so we can work internally on fixing this issue.
Warm Regards,
Mauricio, TSE.
(2,447 Views)
