PXI
Where to get the Phar Lap ETS real-time operating system that supports labview 2018.
Hi everyone, I would like to install a Phar Lap ETS real-time operating system in a virtual machine that can be used with LabView Real-Time2018. Where can I get this operating system?
Thank you!
(1,994 Views)
If you're looking to develop using LabVIEW 2018 RT, you can do it in a regular Windows OS, you need the RTOS just to execute in an RT environment.
Santhosh
Soliton Technologies
(1,964 Views)
Not sure if you need a special ISO for the virtual machine environment. You can create a bootable USB for installing Pharlap from NI MAX. See Using a Utility USB Drive to Format my Real-Time Phar Lap ETS PXI Controller. The utility is loading the file from
C:\Program Files (x86)\National Instruments\RT Images\Utilities\PXI_Disk
https://tmesystems.net/
(1,950 Views)
