PXI
Why am I getting error 200077 on the PXIe-6124 system
My program works well for DAC 6115 and 6110. Now I'm going to apply it to the PXIe-6124 (BNC 2110 borad). When I switch the coupling mode from DC to AC, Error : 200077 occured at Property Property Node DAQmx Channel. More in the attachment. Can anyone help me solve this problem? thanks a lot.
(3,707 Views)
Accepted by topic author renwei
renwei,
Thank you for using the NI Forums. The reason that you are getting this error is because the PXIe-6124 only supports DC Coupling. If you look at the specifications from the PXIe-6124 it has this as "Input Coupling". PXIe-6124 Specifications. As for the 6115 and the 6110 they support both AC and DC coupling, (PCI-6110 Specs) so it appears that your program is trying to set the coupling of the PXIe-6124 as AC Coupling. As long as you set the coupling for the 6124 to DC you will have no problems. Hope this helps.
Message Edited by Aaron W. on 11-19-2009 02:17 PM
Aaron W.
CLA, CTA and CPI
(3,684 Views)
Thanks, Aaron!
(3,635 Views)
