PXI
Why can't I use a pointer as an argument?
Here is an example of a function...
// Function prototype
int foobar(unsigned int a, int *b);
// Function
int foobar(unsigned int a, int &b)
    // Acquire some data... then
    b = Data[a];
I get the following error:
73, syntax error; found '&' expecting ')'.
This is the normal method of passing in a pointer to an integer to a function and then setting the contents of the integer in the function. Why doesn't CVI let me do this? Is there another way?
(3,354 Views)
sorry cannot answer that one!
But I would suggest you to post your query in LabWINDOWS/CVI Discussion board and you can assured of a quicker reply/solution
(3,348 Views)
Probably.
I didn't even look at what board I was on. I submitted this one here because of a similar post was on this board.
Guess I'll repost.
I was wondering what all these PXI posts were doing here.... 😉
(3,340 Views)
