PXI
Why do I get error "-1074388885" when using CANopen in PXI RT?
Dear all,
I built a test program (reading only the temprature of a motor) to use it later to exchange data between NI- PXI RT  and a LUST servo controller, which are locally connected with CAN network. Please see the attached VI. After run the program , a communication error with CAN network is happend. The error code is (-1074388885; CANopen NMT send.vi) after that the RT-Target give an error a message:
 (impossible to connect to target Real-time)
and then switched off. To connect it again, switched off/on of power supply has to be done.
I test the CAN connection between them with MAX, the test results give no problems.
Normally this test program was before running  correct between PC (with NI CAN-card) and Lust servo motor.
Does anybody have a solution?
Regards
al_ibr
Message 1 of 8
(4,772 Views)
Could you provide the version of LabVIEW and MAX that you installed?
Which hardware do you use?
Regards
Yann C.
France
Message 2 of 8
(4,752 Views)
Hi Yann, Many thanks for your reply. The LV version is 8.6 and MAX is 4.5. The PXI RT has the following data: NI PXI chassis: 1031 NI PXI embedded controller: 8104NI PXI CAN card: 8461 The servo controller (Lust CDD3000) has a CAN card LUST CM CANI (see attached documentation). The equivalent program in PC with NI PCI CAN/2, which tests the data exchange with this servo controller, is attached (works without any problem). I attached the project file for the test program in PXI RT. Regards al_ibr
Message 3 of 8
(4,733 Views)
Can you try test_progr_CAN_non_RT.vi directly on your PXI target. Just create a new LabVIEW project with your PXI target, add  test_progr_CAN_non_RT.vi under calculDroit target and launch the Vi.
Do you have an error?
Regards
Yann C.
France
Message 4 of 8
(4,710 Views)
yes, I got the same error (begining by start remote node).
Regards
al_ibr
Message 5 of 8
(4,694 Views)
Can you provide a screenshot of all software that you installed on your PXI?(by using MAX)
Below you can find some KB related to CanOpen and RT Target:
Setup an NI-CAN Real-Time Application in MAX
Startup Application with CANopen VIs on Real Time Targets
Hope this helps.
Regards
Yann C.
France
Message 6 of 8
(4,678 Views)
Hello Yann,
Find below the schreenshot of PXI-Software.
I will let you know, if the Information provided in the link will help.
Regards
al_ibr
Message 7 of 8
(4,669 Views)
Hi Yann,
I tried with the provided information in the Links (included in your last reply). First I download the CAN chanells to the RT. Then I discovered that one file is missing (cvi_lvrt.dll) in the RT, as mentioned in the second link. It was difficult to put this file beside the existing one (ni_cano.dll) in the project tree, as described in the end of the second link.
I could only did a normal transfer through MAX using FTP_explorer (but I could not see it in the project tree).
After run the program, the same error is happend.
Regards
al_ibr
Message 8 of 8
(4,618 Views)
