PXI
Windows 7 Certified Driver
I am using a PXI-1033 chassis with a PXI-1411 image aquisition card and a third party camera. I have written a program running on a Windows 7, 64-bit machine. I occasionally get an exception which causes the program to shut down without correctly shutting the camera interface. On subsequent runnings of the program I get an error on this interface.  What I have figured out is that the device driver is not automaticaly obtained on rebooting the system and it chooses the wrong driver. It creates a second PCI-PCI bridge instead of choosing the NI Enumerated Device driver. When I correct this, without doing anything else the program will run no problems. I believe the issue to be that the driver is not Windows 7 certified. Does this driver exist? Is there any way to ensure that the chassis chooses the correct driver on reboot?
(3,965 Views)
Hey Turtle33,
I checked the readme on the most current IMAQ drivers and it does show that the IMAQ driver allows compatibility between the 1411 card and Windows 7 64-bit.
So the million dollar question is what version of IMAQ do you have? If it is 4.3 or below, then you need to update.
Hope this helps!
A. Zaatari
(3,939 Views)
Thank you for your reply.
I am using IMAQ version 4.4, it seems to be grabbing the wrong device driver because it creates this second PCI-PCI bridge in the device manager. If I go into the manager and correct it, it runs just fine. I do not get this problem everytime the program stops, either by design or because of an error, just sometimes.
(3,936 Views)
Hey Turtle33,
Can you go ahead an update the driver anyway and see if there is any improvement?
A. Zaatari
(3,926 Views)
