PXI
Windows NT on PXI-8156 won't boot.
A virus corrupted the winlogon.exe file and now the system fails with an error C000021A when trying to boot. I have no CD-ROM drive attached and cannot get into the system to restore the winlogon.exe file. The boot floppy disks stop when they can't find a CD-ROM drive.
(3,521 Views)
The following KB discusses how to boot without a CD-ROM - KB 2NB7C3WD. You should then be able to make changes via Ethernet.
(3,520 Views)
This was usefull but; I do not have a domain to log in to so was unable to access the ethernet network. Also, the drives were formated as NTFS and therefore unaccessible from DOS.
(3,520 Views)
Try these two KBs: KB 2IKA5RLS , KB 1X0H52KS. These show how to set the bios options to not look at the CD, and also how to create a boot disk. You might also look to the Microsoft web site for help creating a boot disk that will read NTFS files.
(3,520 Views)
