PXI
With NI4461 using DAQmx whether to use C++ or C# for performance and other reasons
For performance reasons and for other factors in consideration what is the commonly used language for programming DAQmx.
a) What is a good option to interface with the drivers - C++ or C# or anything else ? b) What is commonly used by the programmers for these cards ?c) If there any performance related aspect that should determine the use of programming language?
Nirdesh
(3,394 Views)
Hello Nirdesh,
The best language to program DAQmx is LabVIEW>You will find details about it at the following place:
https://www.ni.com/en/shop/labview.html
However you can also use text based programming language to program it. The following weblink discusses it:
https://www.ni.com/en/support/documentation/supplemental/18/programming-ni-daqmx-and-traditional-ni-...
Do let us know if you have further issues.
Regards
ga101
(3,333 Views)
