PXI
Write in tdms file from PXie
Hi Every one
I am using Pxie 4330 to measure/acquise data from strain. I want to write data in tdms file, but there is an error occured in tdms open? it only occures when I open the VI under project.
Do you have any idea what is the problem ? when I open the Vi not under project the file dialog works well but under project NO.
Message 1 of 11
(6,292 Views)
Hi EricMgNiBh, what is the error code returned? The error code is returned when you creating the  new TDMS file or opening an existing TDMS file?
Message 2 of 11
(6,292 Views)
Hi
the error occured in creating new TDMS file or either existing , the error code returens the file path is not supplied , I can tell you the error numer in a minute.
I think is because of target and pxie, because the VI alone works well.
Message 3 of 11
(6,287 Views)
Hi I attached the photo .
O followed labVIEW examples ,
Message 4 of 11
(6,280 Views)
It looks like the error is originally generated from the file dialog VI, instead of TDMS. Please try just input some constant of the file path to TDMS Open and see whether the error will come up again.
Message 5 of 11
(6,277 Views)
I did, I connected control path directly to open TDMS but again error occured.
Message 6 of 11
(6,274 Views)
That's interesting. Is still the error 43? And did you try just copy the code of TDMS nodes and try to keep the VI as simple as you can, and can the simple VI still return the error?
Message 7 of 11
(6,269 Views)
error sometimes turned to 63 which say the path fill is not supplied. the error for open TDMS and dialog user only happens under target ( pxie ), in simple VI the user dialog works well. but I have to run my VI under my target ( PXI) because of measuring data from strain.
Message 8 of 11
(6,267 Views)
Are you trying to run that TDMS open on an RT target?
RT targets have no UI, so a dialog box will not work.
Chris
Certified LabVIEW Architect
Certified TestStand Architect
Message 9 of 11
(6,257 Views)
thanks so even if I have use direct path it is not gonna work ?
Message 10 of 11
(6,246 Views)
