PXI
Write text to file produces error 1
The attached vi attempts to write text to a text file. The file name is automatically created from the current date (no file dialog box shall be displayed). When I run the vi, I receive an error 1 and no file is being created.
(3,382 Views)
To answer your question: The file path input of the Open/Create/Replace File.vi refers to a complete file path including the file name. I have modified your vi by concatenating the Location of Log File control with the Date string and using that as a file path. This runs perfectly without any errors.
Ankita A.
(3,382 Views)
Hi Ankita,
Thank you very much for your help. The modified vi that you sent me works fine.
Peter
(3,382 Views)
