PXI
XML on real time
Hi all,we have developed a VI to parse an XML file using .NET methods and properties. We want to deploy it on a PXI-8110 real time system. The VI is not executable and the error list shows "Type not supported in current target." for each wire and node. We believe that .NET methods are not supported on real-time systems.
How can we solve this problem? Do you know if it is possible to use any libraries that don't use .NET methods?
Jessica
(3,358 Views)
Hi Jessica,
you can find XML palette on LV RT < 8.6
cheers!
Marco
MarcoMar
National Instruments Italy
(3,350 Views)
