PXI
XNET 20.5 + PXI-8513 + Veristand 2017 and Phar lap on PXIe-1085: deploy error
I'm tryng to replicate this example to deploy a CAN Loopback using PXI-8513 installed on PXIe-1085 chassis.
When I try to deploy to the target machine (PXIe-1085) I received an error:
"Remote communication with the LabVIEW RT failed because the host and target version of NI-XNET are different. Solution: On the target, install the same NI-XNET version that is installed on the host".
Is it possibile to install NI-XNET on target machine with Phar lap?
(500 Views)
Accepted by topic author carl578
See Installing Software on Phar Lap Real-Time (RT) PXI Controller
https://tmesystems.net/
(485 Views)
