PXI
about PXI
          we want to use labview for mesurment of current and voltage at various points of my PCB board and  aquire all data and documentation of same. I might be using more than 24 I/O s
 I want to know which PXI will be well suited for my requirement.
(3,951 Views)
There is a bit less information. What is the voltage range, current range, do you require isolation, what is the rate of acquisition???
You can contact NI India 08041190000. They will be able to help you configure the system.
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(3,939 Views)
