11-16-2009 06:44 PM
I am trying to make a VI into my startup executable on a PXI System running LV RT. This VI dynamically calls 2 other VIs. These VIs call multiple subVIs in turn. My first attempt at this process created an Error 42:
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
Error 42 occurred at Create Folder in Create Directory Recursive.vi->AB_Destination.lvclass:Create_Destination.vi->AB_Build.lvclass:Create_Destinations.vi->AB_Application.lvclass:Create_Destinations.vi->AB_Build.lvclass:Build.vi->AB_Application.lvclass:Build.vi->AB_RTEXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller
Possible reason(s):
LabVIEW: Generic error.
C:\FSPR\builds\Engine Monitor\RT PXI Target\SCRAMNetRTApp\c\ni-rt\startup\startup.rtexe\LabVIEW 2009
After reading the instructions in Help and the the KB articles I'm confused. Do I need to make source distribution library for each of the dynamically called VIs? If so, how do I reference them when I build my startup executable? Is this the source of my error? I've enclosed the VI I'm trying to make into a startup executable.
11-16-2009 06:45 PM
11-17-2009 06:44 PM
faustina,
It is a little difficult for me to tell exactly what is going on in your code with out seeing what is in the subVIs. But what I would suggest doing is to start pulling pieces out of your VI to see what is causing the error. It looks like you have determined that this is caused by the VIs that you are calling by reference. If you make these plain subVIs, do you stop getting the error? If you make a simple VI that only calls these VIs by reference do you getting error 42? If so could you post these VIs so that I can see if I can reproduce this?
11-18-2009 05:05 PM
11-19-2009 06:32 PM
In the code that you posted you are still calling VIs by reference. I would like you to just put those VIs in as subVIs, to see if that is what is causing the error you are getting.
thank you
12-02-2009 06:23 PM
same error
enclosed is the modified VI plus PPT document showing how I configured the Build. I need to figure this out soon.
12-04-2009 11:41 AM
12-07-2009 03:05 PM
step 2 enabled me to finally build the VI. I could even modify the build specifications in my original project to those of the new project then build and deploy sucessfully. However, determining the VI is running properly is proving to be a problem. When I deploy the build the .exe and .alias files are placed in the c:\ni-rt\startup directory. Then I reboot the PXI System and it crashes soon after startup. Startup proceeds as normal, with the startup application beginning, up until the VISA Server begins. Then the System crashes. If I reboot into safe mode, delete the .exe and .alias files, then reboot into standard LabVIEW RT, the PXI System STILL thinks it is beginning the startup application located in c:\ni-rt\startup directory. Why is this? The PXI System does not crash and seems to be running the startup application without incident. I don't know for sure, that's why I want to run the debugger. However, when I ask to run the debugger from the Project Explorer, LabVIEW cannot find the VI. I assume this is because the .exe and .alias files have been deleted from the c:\ni-rt\startup directory. Correct? So what fundamental RT stand-alone concept am I missing?
12-07-2009 03:20 PM
12-08-2009 05:51 PM
the original error that started this thread seems to be gone
It doesn't seem to matter whether the debug is enabled on the startup exe or not. The system still crashes right after bootup with the following:
NI-VISA Server 4.5 started successfully
Welcome to LabVIEW Real-Time 9.0
Internal Error: [0...19] nxnxnxn_nxnxnxn_nxnxnxn Scheduler Assert : 1667: If you have enabled serial console error logging, detailed error info could be found at that console.
I created a default RT Project with LabVIEW and that made that target VI a startup exe. It runs at bootup, however, I cannot get the host VI to run because of target issues. I think this KB describes it. http://digital.ni.com/public.nsf/allkb/F60F12FC5B3B2161862571160081AA88 However, I don't see the Autodeploy option for the SV library.
