PXI
calculating Va and Vb (secondary coil voltage) of LVDT using PXIe-4340
Hi myself Fuzzic,
        Im using PXIe-4340 module to calculate the voltage of LVDT as im trying to get the actual value of voltage in test panel, it only shows position or displacement of core in LVDT
how can i get the voltage of Secondary coils in LVDT, Cause im developing an labVIEW application to check the accuracy of the LVDT
I have also observed that one channel only shows the one value even if i have connected Two wires of secondary coil of LVDT Because it only show displacement i guess????
Can any one tell me the proper way to find the two different Voltages of Secondary coils of LVDT in PXIe-4340 Module
Thank you,
Fuzzic
(261 Views)
This example seems to read the Va and Vb samples and compute the displacement in software,
Measuring Angular Position with a Resolver and the PXIe-4340 - NI Community
Santhosh
Soliton Technologies
(235 Views)
