PXI
can I use a PXI-4462 board for single sample analog voltage read?
I need to read the voltage from a position sensing device at a rate of 500hz to 1 khz. That voltage signal will provide feedback for a PID control loop, so I need close to "real-time" voltage reading.
From what I can understand from the documentation, it seems like this device is meant for high rate of sampling, and it provides the frequency content of the signal provided to it. I'm just wondering if it can be used for the more simple case of analog voltage single sample in a timed loop.
Message 1 of 1
(1,764 Views)
