PXI
connecting NI6602 to an 20pin Hardware
Hi all,
Could any body explain me the step by step procedure to connect NI6602 to an Hardware having 20pin(I/O) a generic embedded system which responds to the signals sent by the sensors.
 Details of the setup:  Labview 8.2,NI6602 ,PXI chassis.
If any body having the test setup enviornament  photograph..would be usefull for all.
Thanks in advance.
NAG
(3,009 Views)
NAG,
Thanks for contacting National Instruments.  Hopefully some other users will post their solution if there is one out there that is specific as you need.  We do offer our connector blocks that you can use to break out the different lines from your 6602.  Using the pinout (see page 4) for the 6602 you can determine which counter lines you need and connect them as you see fit.  We do also have other connector blocks, and the best way to see them is to go to the product page for the 6602 and look at the accessories, and be sure to click on "Show More Options" on the right.   I hope this helps, and hopefully someone with a specific application will post as I don't have a similar setup here.
Kenn North
Principal Product Manager - Search, Digital Analytics
http://ni.com/search
(2,991 Views)
